Question about service CSTacacs and delete AAA Client?
Nov 10th, 2009
I am running the ACS and all this good, I delete a AAA client of the ACS, try logging in again and let myself go! .. I had to restart the service CSTacacs to not allow access to the AAA client is well removed ..this is correct? or is there some way to correct this? .. Thanks!
Jagdeep Gambhir Tue, 11/10/2009 - 08:32
  • Red, 2250 points or more
Yes, when ever you make any changes it is recommend to reload the services.
Use Delete+Restart option instead of Delete.
Incase Delete+Restart does not makes any difference then try updating Java or try with different browser.
~JG
Do rate helpful posts
Kevin Morales Tue, 11/10/2009 - 08:51
I change the IP to the Client AAA, and restart the service CSTacacs and will not let me login with the user..
Jagdeep Gambhir Tue, 11/10/2009 - 10:40
Please provide more details...you are not able to login to that aaa-client or acs itself?
Kevin Morales Tue, 11/10/2009 - 11:05
if you change the IP to the AAA client, this lets me log into the user configured in ACS. I have to restart the service CSTacacs not let me log into the user of ACS and local users can use the router.
