11-10-2009 09:01 AM - edited 03-15-2019 08:26 PM
Hello All,
I have installed and configured Presence 6.0.5 with CUCM 6.1.4.
I have connected a Personal Communicator and controls devices, access unity, and also works as a phone if needed, all but presence. I see the error in Help - Server Status, and shows that can not connect to the server. The server is already configured in Presence Server , under Application, CUPC, Proxy server. Any idea? Thanks in advance.
Solved! Go to Solution.
11-10-2009 09:31 AM
Hi!
Make sure that the IP phone you are using has an owner ID associated to it.
Aslo check this:
1. Cisco Unified Presence --> Proxy Server --> Incoming ACL page.
2. Add new incoming ACL.
3. Set "ALL" in Address Pattern.
In the CUPS web admin page go to Presence > Proxy Server > Method/Event Routing. You should see 3 entries there - for PUBLISH, SUBSCRIBE and profileconfig. All the routes above should use destination port of 5070 and destination address of CUPS.
Teresa.
11-10-2009 09:31 AM
Hi!
Aslo check this:
Teresa.
