Nov 10th, 2009
I have switch 2960-24-TC-L ,and module SFP
GLC-LH-SM , when connect the SFP to switch see this message
Mar 1 00:07:45.785: %GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port Gi0
/1 has bad crc
but i'm know from data sheet the 2960 support GLC-LH-SM , when i execute the command
#sh inventory don't see the module her
what's problems
Bobby Thekkekandam Tue, 11/10/2009 - 11:54
Is this a Cisco SFP or a Non-Cisco SFP?
Cisco-approved Small Form-factor Pluggable (SFP) modules have a serial
EEPROM that contains the module serial number, the vendor name and ID, a
unique security code, and cyclic redundancy check (CRC). When an SFP module
is inserted in the switch, the switch software reads the EEPROM to verify
the serial number, vendor name and vendor ID, and recompute the security
code and CRC. If the serial number, the vendor name or vendor ID, the
security code, or CRC is invalid, the software generates the aforementioned
security error message and places the interface in an error-disabled state.
If you are certain that this is a Cisco SFP, the EEPROM may be corrupt, and you would need to open a TAC case to get an RMA.
Hope that helps,
