CUCM7 and Billing server
Nov 10th, 2009
  • Bronze, 100 points or more
Hi guys, If I configure the billing server in CUCM->CDR Management and all CDR data files are exported to that server, the CDR data files are deleted from de CUCM and I will not be able to use the CAR tool for additional call reports??
Thanks a lot
David
htluo Tue, 11/10/2009 - 14:57
  • Red, 2250 points or more
The CDR data will not be deleted just because they are exported to billing server.
The longevity of the CDR data was controlled in CAR Admin > System > Database > Configure Automatic Purge.
Michael
http://htluo.blogspot.com
david-lima Tue, 11/10/2009 - 16:31
Hi htluo, thanks for the info, just these questions please:
1. What is the format of these files (*.dbf), can I use these files with a customized billing application.
2. When I use the run sql command for an specific query: run sql select authcodedescription from car:tbl_billing_data where originalcalledpartynumber='3225'
The result show me as NULL, do I need to configure something else??
Thanks for your help agai
David
david-lima Tue, 11/10/2009 - 17:50
Hi htluo, is there a way to connect to the Informix Dynamic Service using an ODBC driver connection (for example: TOAD).
Thanks a lot for your help
David
