11-10-2009 05:55 PM
I have a WRVS4400N router and I recently tried to upgrade the firmware from V1.1.13 to V2.0. When I perform the upgrade it gets to about 4% and then I get this message.
"Upgrade file is not the correct type or version for this device. Upgrade failed. Please obtain the correct file and try again."
I thought it might have been a corrupt file so I downloaded the file again to a different computer and the results were the same. If anyone can help I would appreciate it.
The zip file I downloaded was
WRVS4400N_V2.0_Firmware.zip
The file I used to upgrade was
WRVS4400Nv2-fw-2.0.0.7-K9.img
System Info
Firmware Version: | V1.1.13 | DRAM: | 64MB |
CPU: | STAR 9202 | FLASH : | 8MB |
System up time: | 70 days, 07:10:28 |
David
Solved! Go to Solution.
11-11-2009 05:45 AM
Hello David,
There are 2 hardware versions of the WRVS4400N. The version 1.0 and 1.1 use different firmware than the version 2 platform.
Going on the version number of firmware on your router, you have either a version 1.0 or 1.1 device and the firmware you are trying to upload to the router will not work. It is specifically for the version 2 platform.
Firmware version 1.1.13 is the most current firmware available for your router.
Jason
11-11-2009 08:51 AM
IPS signatures should be able to be used across hardware version platforms.
11-11-2009 08:52 AM
At the cisco.com website, you can download the ips signature 1.41. That should upgrade your ips on your router.
11-11-2009 05:45 AM
Hello David,
Jason
11-11-2009 08:37 AM
Thanks Jason, Than I have one more question I keep getting a notice that my ips file is too old. Where is the lastest version of the ips or can I use the one in the V2.0 firmware package?
Thanks again for the fast response
David
11-11-2009 08:52 AM
11-11-2009 08:51 AM
11-11-2009 10:47 AM
Thanks all
03-15-2010 06:22 AM
May I, nevertheless the positive closing by dytanaka1, add the question: when does cisco intend to provide an updated IPS signature file? I mean, 6 months in behind are light years for security matters, aren't they!?!
Thanks in advance for giving us an idea about this date.
Martin
10-31-2010 04:13 PM
I am also now requesting an update. Recently purchased for client, in use, message states: "Your Signature Version is beyond 14913 days. Please Update it!"
That is sure a lot of days!! And it's version 2?
Please, is this hardware dead, obsolete, unworthy for sale?
If so, what is the replacement?
And finally, if no longer supported, yet still on store shelves without disclaimers that it is obsolete would warrant a refund?
11-02-2010 06:41 AM
Have you updated the latest ips signature from cisco.com? The error message is stating that the ips signature is out of date. We were getting alot of issues with this at the beginning of the year but they released a new signature that resolved the issue.
