Can not access ASDM on ASA 5510?
Nov 10th, 2009
Dear All,
I had ASA5510 and i want to opent ASA 5510 by ASDM ,
So i can open it but when i click configuration it tell that:
you are authorized to access only home and monitoring Views
How can i have authorized to change something on ASA 5510.
Best Regards,
Collin Clark Wed, 11/11/2009 - 08:25
A username with level 15 privileges needs to be configured. Do you have telnet or SSH access to the device? If so you can create a username similar to the following;
username mmessier password GoRaNgErS privilege 15
Hope it helps you out.
rechard_hk Wed, 11/11/2009 - 18:33
Dear collin,
Thank for you advise!!!
i'm not clear about user privilege 15, so what does it mean?
How can i do if i would like to some user can access ASDM (Read-write) and other user can access (Read-only) i mean can View and monitor?
I mean that:
1- username A passowrd A (Full access ASDM)
2- username B password B (View and Monitor only)
which command that i do ?
Best Regards,
Collin Clark Thu, 11/12/2009 - 07:32
Here's a link how to set it up.
There are 16 levels of authorization, 0-15. 15 has the highest privilege level and 0 the least. These are not in the config until you configure different levels. What we do is take the commands that will allow read-only and move them down in privilege level (level 5 in the link). Then we create a username at privilege level 5. They can now use the commands we moved down to their level. Users at a level also have access to commands below them.
