E1 Question
Nov 10th, 2009
Hello everyone,
I was wondering what is the maximum distance between an E1 Modem (Voice) a Voice Gateway?.. Isn't it the regular Ethernet standard of 100m?
I was wondering this because i have this case where the distance between the modem and the gateway around 200-250 m.
any ideas how to overcome this distance barrier?
Ahmed
christoph.hable Wed, 11/11/2009 - 05:05
I would say it depends on the cable :)
If you gonna use a default cable with RJ45 connector and 120 Ohm it should be no problem to master 200-250m.
I just asked a colleague and he told me with the right cable you can get 1000m as well.
BR,
Christoph
