Integrate user's information (phone numbers, department,etc) with LDAP
Nov 10th, 2009
Do somebody could probably provide me link that describes inegration LDAP with CUCM?
What advantages I'll receive after integration? Thank you a lot!
Jaime Valencia Wed, 11/11/2009 - 07:00
The info is already on the web so you can look for it, bookmark this and whenever you want info search here first
Cisco Unified Communications Manager (CallManager)
Introduction
http://www.cisco.com/en/US/products/sw/voicesw/ps556/tsd_products_support_series_home.html
No info on version so i'll say it 7.1(2), refer to the 3 ldap topics
LDAP System Configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b02ldsys.html
If you want to understand the advantages tead the LDAP chapter from SRND
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
