C4006 Boot problem
jorjes1984
Dear all
I am having a problem in my C4006 during the boot.
While Booting the switch, i get in the end the following error: "Your ROMMON version is obsolete"
I tried to download another IOS and boot the switch using the boot tftp command from the rommon mode but still had the same problem,
I put below the whole BOOT log that i am receieving, please advise what to do to boot the Switch successfully as it is urgent.
rommon 15 >boot tftp://10.100.100.155/cat4000-i9s-mz.122-18.EW7.bin
Tftp Session details are ....
Filename : /cat4000-i9s-mz.122-18.EW7.bin
IP Address : 10.100.100.1
Loading from TftpServer: 10.100.100.155
Received data packet # 20078
Loaded 10279472 bytes successfully.
Rommon reg: 0x37004180
Running diags...
Decompressing the image
########################## [OK]
k2diags version 2.4.2_b
prod: WS-X4014 part: 73-6854-08 serial: JAB061405LZ
ManPm8351: using limited loopback
Power-on-self-test for Module 1: WS-X4014
Port/Test Status: (. = Pass, F = Fail)
Reset Reason: Software/User
Port Traffic: L2 Serdes Loopback ...
0: . 1: . 2: . 3: . 4: . 5: . 6: . 7: . 8: . 9: . 10: . 11: .
12: . 13: . 14: . 15: . 16: . 17: . 18: . 19: . 20: . 21: . 22: . 23: .
24: . 25: . 26: . 27: . 28: . 29: . 30: . 31: .
Port Traffic: L2 Asic Loopback ...
Port Traffic: L3 Asic Loopback ...
24: . 25: . 26: . 27: . 28: . 29: . 30: . 31: . au: .
Switch Subsystem Memory ...
1: . 2: . 3: . 4: . 5: . 6: . 7: . 8: . 9: . 10: . 11: . 12: .
13: . 14: . 15: . 16: . 17: . 18: . 19: . 20: . 21: . 22: . 23: . 24: .
25: . 26: . 27: . 28: . 29: . 30: . 31: . 32: . 33: . 34: . 35: . 36: .
37: . 38: . 39: . 40: . 41: . 42: . 43: . 44: . 45: . 46: . 47: . 48: .
49: . 50: . 51: . 52: . 53: . 54: .
Module 1 Passed
Exiting to ios...
Rommon reg: 0x37000180
Running IOS...
################################################################################################################################################# [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(18)EW7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 13-Oct-06 11:13 by ccai
Image text-base: 0x00000000, data-base: 0x010A6974
Rebooting in 10 seconds...
10 09 08 07 06 05 04 03 02 01 00
%Software-forced reload
simontibbitts
Hello.
I do not think you have downloaded the correct software. When I look at the release notes of 12.2EW it does not say that your supervisor III is supported:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_5184.html#wp16938
Try 12.1(11b)EW1. The release notes for this says your SUP (WS-X4014=) is supported:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_3739.html#wp16938
Simon
glen.grant
From what I can tell the image he is using is ok but my guess he is coming from some ancient code version and the rommon needs to be upgraded first before trying to load to newer code . The code looks to be valid under a sup 3 download . Find the newest rommon version for the sup 3 and upgrade that before trying to load the new code. Follow rommon upgrade instructions strictly , if done incorrectly it can render the supervisor inoperable. This looks like it might be the latest version for a sup III.
cat4500-ios-promupgrade-122_31r_SGA
Release Date: 11/Sep/2006
Catalyst 4500 Supervisors II+, II+TS, II+10GE, III, IV, V, V-10GE, and Catalyst 4948, 4948-10GE, ME-4924-10GE ROMMON upgrade.
Size: 445.92 KB (456616 bytes)
Do you have any good guide for the rommon upgrade??
