IDSM-2 slow file copy
Nov 11th, 2009
Hi, I have FWSM and IDSM/2 module on 6500 switch in my network, and we have issue with file transfer between some machines. When server is behind IPS, transfer is very slow, 40x lower then in situation when server is only in VRF/FWSM - without IPS. Any idea? Thanks in advance
andrey.dugin Wed, 11/11/2009 - 01:45
  • Bronze, 100 points or more
Check your IPS interfaces load. May be it is overloaded.
binelipetrov Wed, 11/11/2009 - 01:50
In which way can I do it? Show interface command via console only showing number of packets per VLAN group. The same thing via Web GUI - only cumulative number of bytes
Thanks in advance
andrey.dugin Wed, 11/11/2009 - 06:07
SNMP statistics, MRTG for example.
You may monitor IDSM2 inline interfaces or switch ports connected to IDSM2.
rhermes Wed, 11/11/2009 - 08:54
  • Gold, 750 points or more
an overworked sensor can certainly be a cause of problems. The easiest way to determine you sensor's health is to look at the % missed packets and CPU utilization from the CLI:
sh int (%missed pactets)
sh stat host (CPU)
If those don;t look like the cause of your problem, a likely cause is the normalizer engine sigs. These sigs will drop packets it doesn't like and not give you an alert. Check what sigs are fireing when you're experiencing this problem:
show event past 01:00 | include (whatever you're looking for)
