How do I configure Multicast Bridging on FWSM with multiple context.
Nov 11th, 2009
Hi There
Can't find any information regarding this feature, what I have found states that it is a feature, which only is supported when Your context is running in transparent mode, is that true. ???
Thanks in advance.
Panos Kampanakis Wed, 11/11/2009 - 08:32
Currently we
only support multicast routing in the single routed mode. It is not
supported in multi-context mode. We do support multicast bridging, but
this would require transparent mode versus routed(only need to allow
multicast traffic via an ACL then). In addition, the
multicast routing is limited to 8 interfaces.
I hope it helps.
j.damsgaard Fri, 11/13/2009 - 05:29
Thanks for Your reply.
I have recommended 2 approaches to my
Ad 1.
Move the clients that are to receive the multicast traffic onto the VLAN with the Multicast servers.
Ad 2.
I can build a setup with a seperat set of PIX hardware to move the multicast traffic onto the costumers secure network.
