translation rule help
Answered Question
Nov 11th, 2009
Is there a way of adding more rules to a translation rule. I have a translation rule which has a max 0-10, and I need to add some more. If I create a new translation rule and apply it to an interface it overites the original.
Correct Answer by Brandon Buffin about 7 years 3 months ago
You can have up to 15 voice translation rules. Only 1 translation profile can be applied to an interface in each direction(inbound/outbound). Another option is to use the "num-exp" command.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Wed, 11/11/2009 - 13:04
Hope this helps.
Brandon
Martyn Sharpe Wed, 11/11/2009 - 14:13
I must have an older version of IOS as it will only go to 10 voice translation rules and they already have 10 set up. It was setup prior to my involvement and not very efficient. Thank you for your reply and I will look at the "num-exp" command
Martyn
