Remote Extension via Internet configuration
Nov 11th, 2009
Sorry if this topic is covered already but I can't find an answer...
I want to connect an IP phone (either hardware or softphone) to the SPA9000 from internet (not via VPN)
Firstly my SPA9000 is behind NAT firewall. This firewall is configured to direct UDP port 6060 to the IP address of the SPA9000. I can setup softphone such as X-Lite and PhonerLite within the LAN and it works fine. However if I setup from Internet location the phone registers ok and a dialed extension will ring but when picked up neither party can hear eachother?
NAT Support Parameters
Handle VIA received:    Yes   Handle VIA rport:       Yes
Insert VIA received:    Yes   Insert VIA rport:       Yes
Substitute VIA Addr:    Yes   Send Resp To Src Port:  Yes
STUN Enable:            No    STUN Test Enable:       No
STUN Server:                  EXT IP:                 xxx.xxx.xxx.xxx (external ip of firewall)
EXT RTP Port Min:             NAT Keep Alive Intvl:   15
softphonesetup:
Proxy:          xxx.xxx.xxx.xxx:6060
Stun Server:    [blank]
username:       9yy
password:       [Phone ext password] as defined in SPA9000
softphone shows: sip:[email protected] Registered
Any help is greatly appreciated.
Jim
William Childs Thu, 11/12/2009 - 04:48
Jim,
Try changing the extension of the offsite phone. I have found that if you define 800 (my case was a hunt group) as a different extension, it will not work properly.
I would set their exentsion to something in the 400 or 500 range to see if that will resolve the issue. The reason I think the 800 and 900 extension give problems is the SPA400 mailbox manage and deposit number is 800 and 900.
Good Luck,
Bill
jim.snowdon Thu, 11/12/2009 - 05:20
Hi Bill
I'm sorry but I fear that I have mislead you! The external extension starts 7 (actually 702) not 9. Also I can add some more information..
The external extension will only register if I specify "Domain/Realm: [ip-spa9000]"
also if an INTERNAL extn calls the EXTERNAL one the internal caller can be heard on the external but not visa-versa.
if the EXTERNAL extn calls the INTERNAL it rings but when answered neither party can be heard.
Jim
William Childs Thu, 11/12/2009 - 07:29
The username is the item the 9000 cares about. When the phone registers with his userid, that is how the 9000 knows how to get to that user. The extension doesnt really matter at that point. If you login to the 9000, at the top right of the page there is a link to PBX Status. This tells you the devices registered to the 9000. The associated IP address is how it knows to send calls to X user.
Example:
user-id = 204
ip address 192.168.1.57 then it will say how long the registration has left
try changing the user id of the offsite phone.
Bill
lukasz_naumowicz Mon, 01/25/2010 - 04:46
Hi Bill,
We still can't get SPA9000 working in a scenario where phones are registering from Internet to a SPA9000 in LAN. There are issues with registering phones and RTP. Is this scenario, officialy supported by Cisco(you work in Cisco right?).If it's supported are there any guides that could explain how it should be configured?
I'm asking beacuse I'm not sure if we shuould convince customers to buy SPA9000 for such deployments.
Using VPN between phones and SPA9000 is not a solution in our case.
Thank you!
Lukasz
Alberto Montilla Mon, 01/25/2010 - 08:16
Dear Lukasz;
This configuration is not supported not recommended by Cisco. VPN is always required.
Regards;
Alberto
lukasz_naumowicz Mon, 01/04/2010 - 06:25
Dear Jim,
I've encountered similar problems, did you manage to get voice working properly on remote extensions connected to SPA9000?
Best Regards,
Lukasz
jim.snowdon Mon, 01/04/2010 - 08:50
Dear Lukasz
Regreatably not the way I wanted! I have got it working by using a VPN between the remote PC (running the x-lite 3 softphone) and the LAN in which the SPA9000 resides. It is not the ideal solution for me but is workable.
Jim
Related Content
