Wireless LAN Controller
Nov 11th, 2009
Guru's who have implemented Wireless LAN Controller, any recommendation or watchouts based on experience.
Collin Clark Wed, 11/11/2009 - 09:23
I'm no guru but I deployed a few and they're slick. Super easy to configure and maintain. Check out the configuration guide, that's all I followed.
Hope it helps.
Leo Laohoo Wed, 11/11/2009 - 13:29
A tall order you have there.
Like Collin, I go through the release notes of the firmware you are running to find out and bugs you might run over.
Go through the configuration guides of the firmware you are running. The list can be found here:
Various configuration examples can be found here:
Hope this helps. Please rate when you find my post helpful or applicable.
