Nokia (N82) SIP Client setup
Nov 11th, 2009
Anyone successfully setup Nokia SIP client (my cas Nokia N82) as extension on SPA9000?  Nokia phone cnnected to local LAN via WiFi.
I have tried various permutations without success! Any clues to correct parameters greatly appreciated.
Jim
William Childs Thu, 11/12/2009 - 04:51
  • Bronze, 100 points or more
Jim,
The only thing that should be needed on the Nokia phone is a username and the proxy server:6060. For example:
username -- 520
password -- blank/empty
proxy -- 192.168.1.20:6060 (assuming 192.168.1.20 is the ip of the 9000)
Bill
William Childs Thu, 11/12/2009 - 04:57
Jim,
I also did some research on the N82 and did not find that it was SIP compatible. This is what I found.
http://www.nokiausa.com/find-products/phones/nokia-n82/specifications
I clicked expand all and did not find any mention of being SIP capable. Please post a link, if you have one, of where the data sheet/product info says it is SIP capable.
Bill
jim.snowdon Thu, 11/12/2009 - 05:24
Hi Bill,
I just made an assumption. My N82 (bought in UK) had the Nokia SIP client already installed so I assumed it would work ok. Anyway I have decided to give up on that and will test instead with the Doro IP700 WiFi phone.
Thanks anyway.
Jim
jim.snowdon Fri, 11/20/2009 - 17:14
ok a bit mor success with the Doro IP700
What I can do...
1. Receive calls from other extensions
2. make external calls
CANNOT do:
1. make calls to other extensions ???/
If I dial another extension from the Doro the number is recognised since I do not get the "call failed" message which I do if I dial a nonexistant extension number. The dialed extension does not ring and there is no ringing tone on the Doro. After a while the call just timesout?
on the Doro:
Profile Name - User 1          WiFiExtension
Username - user 1               778
Password - user1                [extn password]
Domain - User 1                 [spa9000ipaddress]
Registrar Host - user 1        [spa9000ipaddress]
Registar Port:                    6060
outbound proxy                    [spa9000ipaddress]
outbound proxy port               6060
the status in spa9000 webconfig shows the extension as registered....
any clues?
Jim
William Childs Fri, 11/20/2009 - 22:55
Jim,
This typically has to do with the dialplan. I know that with SPAxxx phones (even the WIP3xx) if you are not able to match the dialed digits to a string in the dialplan, then your call will fail regardless of registration. Please check the documentation on the IP700 for proper dialplan configuration.
Bill
jim.snowdon Mon, 11/23/2009 - 02:35
Bill,
I think it is a bit deeper than that. As far as I can tell the IP700 does not have a facility for a dialplan, it just accepts anything. Further testing reveals that when the IP700 is dialed from another extension (SPA942 in this case) the IP700 rings and then just silence when answered, however the SPA942 it still ringing it. In other words the SPA9000 does not register that the extension has answered?I reitterate that if and invalid extn number is dialled from ht IP700 "Invalid Number" is displayed. If I dial an extension that is connected just nothing until timeout. So this must mean that the spa9000 has registered that the IP700 is trying to dial a valid extn no. but for whatever reason just won't connect it ?
The documentation with the IP700 is somewhat vauge but I gather that it is SIP 2.0 compliant. Should this work ok with the SPA9000 (6.1.5a)?
Incidentally, If I connect the IP700 directly to my ITSP SIP account it works just fine.
Jim
Alberto Montilla Mon, 11/23/2009 - 09:39
  • Cisco Employee,
Dear Sir;
Please activate the debug trace on SPA9000 and send us the traces. This will ease the debugging.
Alberto
jim.snowdon Tue, 11/24/2009 - 13:17
Hi Alberto
The attached trace represents the scenario where 701 calls 778 and 778 hangs up without answering....
701 goes to busy tone as soon as 778 drops the call.
Jim
jim.snowdon Tue, 12/01/2009 - 03:16
Grateful for any advise anyone can give to get this to work properly?
Alberto Montilla Tue, 12/15/2009 - 09:09
  • Cisco Employee,
Dear Jim;
Sorry for the late response, I missed this one. The trace you are attaching does not contain SIP information. Please go to the [Line] tab and set the debug option to Full. This would allow me to see the traces.
As an alternative network traces would also help.
Alberto
Related Content
