11-11-2009 07:04 AM - edited 03-04-2019 06:40 AM
I have a network topology as shown in document in the attachment. If second provider doesn't tunnel BPDU packets(i.e. missconfiguration), is it possible to have a layer 2 loop? Will PROVIDER 2 drop bpdu packets, or there is some mechanism that will take care situations like this?
regards,
A.
Solved! Go to Solution.
11-11-2009 09:15 AM
Hello Antonio,
yes your switches need to be aware that both links are going to the same place unless you are permitting two different sets of vlans with no overlapping it will create a loop.
providers switches cannot distinguish between vlans to be tunneled and vlans to be blocked you need to use
swithcport trunk allowed vlan
to define only the needed vlans that should go over each pipe.
Hope to help
Giuseppe
11-11-2009 07:45 AM
I couldnt view the attach file, however, Tunneling from the provider prespective shouldnt dropp BPDus unless BPDU filtering is configured at the provider edge.
So, the result , with QinQ tunneling , you could still have layer2 loops.
Mohamed
11-11-2009 07:54 AM
11-11-2009 08:26 AM
Hello Antonio,
also the second provider should implement L2 protocol tunneling for STP.
otherwise a loop can occur
the tunnel port should automatically enable bpdu filtering of service provider STP instances.
Hope to help
Giuseppe
11-11-2009 08:15 AM
Yes, In this case , you could end up with layer-2 loop.
Mohamed
11-11-2009 08:30 AM
So this could be or definitely is a layer2 loop?
just a clarification: PROVIDER 1 and 2 has configured dot1q tunneling for my VLANs. SWITCH1 and 2 have trunk on their ports towards PROVIDERS.
A
11-11-2009 09:15 AM
Hello Antonio,
Hope to help
Giuseppe
11-12-2009 12:40 AM
Thanks Giuseppe.
