CUPC Outlook integration..
Nov 11th, 2009
I have a customer who is having an issue when they try to dial from outlook using their CUPC. Outlook is adding a '+9' to the number being dialed and CallManager cannot process the '+'. Has anyone else run into this and if so how did you fix it?
Thanks in advance.
Justin
gogasca Thu, 11/12/2009 - 00:25
  • Green, 3000 points or more
You can use APplication dial rules if using CUCM 7.X
which version you use?
