PIX and default route for VPN clients?
Nov 11th, 2009
Hi everyone!
Weird problem on a PIX515 with 7.2.4: adding the "route inside 0.0.0.0 0.0.0.0 <gw> tunneled" fails.
See below:
PIX-1# sh run | inc route
route outside 0.0.0.0 0.0.0.0 x.x.x.x
route inside InternalNets 255.0.0.0 10.255.x.1 1
route inside 192.168.0.0 255.255.0.0 10.255.x.1 1
PIX-1# conf t
PIX-1(config)# route inside 0.0.0.0 0.0.0.0 10.255.x.1 tunneled
ERROR: Cannot add route entry, conflict with existing routes
Any ideas?
Thanks!
acomiskey Wed, 11/11/2009 - 08:03
  • Green, 3000 points or more
What is he doing should work just fine. I use it on a few ASA's myself.
fsmontenegro Wed, 11/11/2009 - 08:05
Hi Vikram,
I'm doing the same thing in an ASA:
route outside 0.0.0.0 0.0.0.0 y.y.y.y 1
route inside 10.0.0.0 255.0.0.0 10.5.x.x 1
route inside 0.0.0.0 0.0.0.0 10.5.x.x tunneled
Could it be a PIX/ASA difference? Something else? Same thing happens with 8.0.4 code as well.
Thanks!
acomiskey Wed, 11/11/2009 - 08:08
Does it complain if you try adding the inside tunneled route first, then the outside route?
fsmontenegro Wed, 11/11/2009 - 08:12
Haven't tried that as we were accessing the PIX remotely via outside...
Will try to get someone to test it on-site for us.
vikram_anumukonda Wed, 11/11/2009 - 08:11
  • Bronze, 100 points or more
are you saying it's working in ASA, if yes then we are only left with PIX/ASA difference.
what version are you running by the way.
fsmontenegro Wed, 11/11/2009 - 08:13
Hi, I have a separate ASA5520 pair running 8.0.4 that is working fine with that configuration.
This particular scenario is another VPN headend, a single PIX515 running 7.2.x (same thing happened with 8.0.x code).
vikram_anumukonda Wed, 11/11/2009 - 09:09
tried to lookup if there are any bugs, but no luck.
strange issue.
Not sure if a reboot would help.
vikram_anumukonda Sun, 11/15/2009 - 23:00
would like to know if you managed to fix this issue.
