LMS 3.2 Inventory Collection failing
Answered Question
Nov 11th, 2009
Inventory collection is failing for some devices. I ran into this on 3.1 but thought issue was supposed to be fixed in 3.2 I'm attaching IC_Server.log. An example device is 10.69.130.57
Correct Answer by Joe Clarke about 7 years 5 months ago
Then go higher. Make sure you're actually applying the changes.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 11/11/2009 - 08:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Go to RME > Devices > Device Management > RME Devices, and edit the device attributes for this device. Set the SNMP timeout to 10, save your changes, then inventory collection will work.
Correct Answer
Joe Clarke Wed, 11/11/2009 - 09:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
chris.mcgarrah@... Wed, 11/11/2009 - 12:55
I was not appying. I was hitting Modify button, but not Apply button in parent window. It's working now at 10 second timeout. Thanks.
