Static NAT for a complete subnet
Answered Question
Nov 11th, 2009
Is it possible to statically NAT a complete subnet?
I have a need to NAT 10.10/16 to 172.168/16 where 10.10.x.y is NAT to 172.16.x.y.
How can this be done?
Rgds,
Elil
Correct Answer by adamclarkuk_2 about 7 years 8 months ago
Just to elaborate on what Giuseppe has said, here is a configuration example using inside and outside NAT domains and not NVI (which is generally a lot easier to do)
Wan interface
interface FastEthernet0/0
ip address 172.16.0.1 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex half
end
Lan interface
interface FastEthernet1/0
ip address 192.168.1.1 255.255.255.252
ip nat inside
duplex auto
speed auto
end
NAT statement
R1#sh run | inc ip nat
ip nat outside
ip nat inside
ip nat inside source static network 10.10.0.0 172.168.0.0 /24
I then sent ping requests through the router from 10.10.0.1 and 10.10.0.2
Results of show ip nat translations
R1#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 172.168.0.1:4 10.10.0.1:4 1.1.1.1:4 1.1.1.1:4
--- 172.168.0.1 10.10.0.1 --- ---
icmp 172.168.0.2:5 10.10.0.2:5 1.1.1.1:5 1.1.1.1:5
--- 172.168.0.2 10.10.0.2 --- ---
--- 172.168.0.0 10.10.0.0 --- ---
Output of debug ip icmp on destination router
*Nov 11 19:24:04.383: ICMP: echo reply sent, src 1.1.1.1, dst 172.168.0.1
*Nov 11 19:24:25.931: ICMP: echo reply sent, src 1.1.1.1, dst 172.168.0.2
Correct Answer by Giuseppe Larosa about 7 years 8 months ago
Hello Elil,
yes it is possible the
ip nat source static command accepts a network option
this can be very handy in some migration scenarios
p nat inside source static network local-network global-network mask [extendable | no-alias | no-payload | mapping-id map-id | redundancy group-name | vrf name]
see
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_nat.html#wp1011696
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Wed, 11/11/2009 - 09:49
  • Hall of Fame,
    Founding Member
Hello Elil,
see
Hope to help
Giuseppe
elilraj07 Wed, 11/11/2009 - 13:15
Thanks Giuseppe,
This is exactly what i was looking for.
Rgds,
Elil
Correct Answer
adamclarkuk_2 Wed, 11/11/2009 - 11:28
  • Silver, 250 points or more
Wan interface
ip nat outside
duplex half
end
Lan interface
ip nat inside
duplex auto
speed auto
end
NAT statement
ip nat outside
ip nat inside
elilraj07 Wed, 11/11/2009 - 13:14
Thanks Adam,
This is exactly what I was looking for.
Rgds,
Elil
