CUCM 7.0.2 - No Insert Permission when making changes
Answered Question
Nov 11th, 2009
CUCM 7.0.2 Cluster (Publisher and Subscriber)
When making changes in ccadmin get:
Update Failed: No Insert Permission
Add Failed: No Insert Permission
Add Failed java.sql.sqlexception: No Insert Permission
Correct Answer by Jaime Valencia about 7 years 3 months ago
What user are u using??
This on PUB? SUB?
If this happens on SUB only and works on PUB check replication.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 3 (1 ratings)
bernardssupport Wed, 11/11/2009 - 12:31
Its from the SUB (as Administrator). When I try to access ccadmin from the PUB, the URL hangs! (Uh Oh!)
Added: Looks like the Publisher can no longer be contacted. I'll try restrting that box.
bernardssupport Thu, 11/12/2009 - 09:52
Updated: Replication was the issue. Not sure why it stopped but a reboot of the Publisher solved the problem.
