LMS 3.0.1 with DEC 2007 update
Answered Question
Nov 11th, 2009
I have installed LMS 3.0.1 with Dec 2007 update,i have done custom installation and after that i installed 2007 update,after completing installation and update ,when i start LMS the process of LMS are not coming up for very very very long time and all process are down even DCR server is down,attachd are the logs,
Pls suggests Experts,
Thanks in Advance
Correct Answer by Joe Clarke about 7 years 3 months ago
Your SSL certificate has expired. go to Common Services > Server > Security > Certificate Setup, and regenerate the certificate. Then, restart Daemon Manager, and the daemons should start.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 11/11/2009 - 13:44
thomasandy32 Wed, 11/11/2009 - 15:07
Clarke which logs belongs to which module of LMS from where i can get this information so that it will be easier for troubleshooting purpose.
for ex:u asked DCRServer,DCR logs for troubleshooting.
61 process started with waiting for a long time and also the DCR is normal.
Appreciating your help.
Joe Clarke Wed, 11/11/2009 - 16:07
It sounds like you may still have another process failure if processes take a long time to startup. Post the output of the pdshow command from the server.
As for logs, all of them are found under NMSROOT/log on Windows. Some of the logs are named after the processes to which they correspond (e.g. DCRServer.log). However, you shouldn't typically look through logs. Many of them will contain "normal" errors.
thomasandy32 Thu, 11/12/2009 - 00:08
Typing mistake in my above mail the process are normal,I will start discovering devices and if i face problem i will let u know.
