how do I get rid of this ?
Answered Question
Nov 11th, 2009
  • Purple, 4500 points or more
Getting this as a 2851 router boots up . The register is at 0x2102 and the config was originally wiped using a write erase . I know its a command but can't seem to find what i need .
%Error opening tftp://255.255.255.255/network-confg (Timed out)
Correct Answer by Reza Sharifi about 7 years 6 months ago
Hi Glen,
Is this what you are looking for?
To disable this default configuration you simply need to input these commands on your router/switch :
Router#config terminal
Enter configuration commands, one per line.
Router(config)#no service config
Router(config)#exit
Router#copy running-config startup-configThe next time you're going to reboot your router the error message won't be displayed again. That easy!
Reza
Correct Answer by Jon Marshall about 7 years 6 months ago
Glen
Enter this command -
router(config)# no service config
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Wed, 11/11/2009 - 13:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Glen
Jon
glen.grant Wed, 11/11/2009 - 13:28
Thanks Jon , now that i look at that it comes back . Couldn't think of it off the top my head though . thanks..
Correct Answer
Reza Sharifi Wed, 11/11/2009 - 13:17
    2017 LAN
Hi Glen,
Router(config)#exit
Reza
