3825 + NM-1T3/E3 and Sprint T3 line
Nov 11th, 2009
I have replaced ADC Kentrex box with NM-1T3/E3 (the box has failed). After configuring the serial interface, I see the line up and the protocol up but I can't ping Sprint's router as well as they can't ping my router. Sprint is not very helpful because this is not their managed equipment. Any suggestions?
card type t3 2
controller T3 2/0
clock source line
interface Serial2/0
description Sprint (800)877-5045
ip address 144.XXX.XXX.XX 255.255.255.252
ip access-group 100 in
ip access-group 101 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
no ip route-cache cef
no ip route-cache
dsu mode 1
dsu bandwidth 44210
serial restart-delay 0
access-list 100 permit icmp any any
access-list 100 permit tcp any any
access-list 100 permit udp any any
access-list 100 permit ip any any
access-list 101 permit icmp any any
access-list 101 permit tcp any any
access-list 101 permit udp any any
access-list 101 permit ip any any
Richard Burts Wed, 11/11/2009 - 14:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hillel
My first thought would be to verify that the address that you have configued is completely correct.
The fact that the line is up and the line protocol is up is a good sign and indicates that the line parameters match up with Sprint ok. Do you have CDP enabled? If so do you get any information from show cdp neighbor detail (which if it gives you response data will verify the IP address of the peer).
I am not familiar with the dsu mode command and the significance of setting it to 1. Have tested the effect of removing it or of configuring it to some other value?
Rick
paolo bevilacqua Wed, 11/11/2009 - 14:51
  • Hall of Fame,
    Founding Member
Begin sending "show controllers T3". Ask SP if they are using Kentrox or ADC mode on their side.
Note you cannot run T3 speeds as "no ip route-cache cef".
hantonov42 Wed, 11/11/2009 - 15:01
The output for show controllers is
routernyoff01#show controllers T3
T3 2/0 is up.
Applique type is Subrate T3
No alarms detected.
MDL transmission is disabled
FEAC code received: No code is being received
Framing is C-BIT Parity, Line Code is B3ZS, Clock Source is Line
Data in current interval (210 seconds elapsed):
0 Line Code Violations, 0 P-bit Coding Violation
0 C-bit Coding Violation, 0 P-bit Err Secs
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs
0 Unavailable Secs, 0 Line Errored Secs
0 C-bit Errored Secs, 0 C-bit Severely Errored Secs
Total Data (last 24 hours)
65 Line Code Violations, 2 P-bit Coding Violation,
0 C-bit Coding Violation, 2 P-bit Err Secs,
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs,
184 Unavailable Secs, 3 Line Errored Secs,
Sprint told me to set dsu mode to Kentrox.
paolo bevilacqua Wed, 11/11/2009 - 15:06
  • Hall of Fame,
    Founding Member
Good, and show int ser 2/0 please?
hantonov42 Wed, 11/11/2009 - 15:14
Serial2/0 is up, line protocol is up
Hardware is DSXPNM Serial
Description: Sprint (800)877-5045,
Internet address is 144.X.X.X/30
MTU 4470 bytes, BW 44210 Kbit/sec, DLY 200 usec,
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:05, output 00:00:08, output hang never
Last clearing of "show interface" counters 01:40:56
Queueing strategy: fifo
Output queue: 0/40 (size/max)
879 packets input, 32624 bytes, 0 no buffer
Received 605 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
744 packets output, 54596 bytes, 0 underruns
0 unknown protocol drops
0 carrier transitions
DSU mode 1, bandwidth 44210, real bandwidth 44210, scramble 0
paolo bevilacqua Wed, 11/11/2009 - 15:18
  • Hall of Fame,
    Founding Member
Packets go through, I would reconfig interface to absolute minimum and check again.
BTW any chance SP want PPP encap ?
