Single Route Point with Multiple DNs on UCCE
Nov 11th, 2009
Hi Guys,
I had this question from one of our IP Tel Engineers. The reason being it's quicker for him to create 1 Route Point and then create multiple lines(DN) for that RP.
However, I have never done this before and not sure if it's going to work or if it's even supported.
Has anybody done this before? If yes, what's the difference and what's the benefit of doing it this way.
Erwin
erwin.stevanus Thu, 11/12/2009 - 14:46
Hi Geoff,
Unfortunately the CM is version 5.1 so I don't think you can add the RP using the BAT.
I agree with you that it's not a big deal but the question came up because I heard someone has done it before and it works.
So I wanted to see if anyone else has done it as well or if this is supported.
Erwin
