Migration tool From VPN concetrator to ASA ..?
Answered Question
Nov 11th, 2009
  • Gold, 750 points or more
Hi Netpros,
I probably already know the answer .. 'NOPE' .. but want to try just in case some of you had worked out a way of migrating the configuration from a Cisco VPN concetrator to an ASA without having the redo the whole config almost from scratch .. we are talking about 50+ L2L tunnels and several VPN remote groups. Your assistance is much appreciated
Correct Answer by hdashnau about 7 years 6 months ago
Adding to this. TAC can get you a rough conversion of your config through our beta tool but you should do these things if opening the ticket:
1. IMPORTANT: Pull the config off your concentrator as unencrypted XML - Check under Administration>Access Rights>Access Settings and confirm Config File Encryption is set to None (default) and then under Administration>File Management>XML Export you can save off the config file and attach it to your case for me.
2. Name of your Account Team or SE.
3. Current version of code the concentrator is running
4. Current version of code on the ASA and the ASA platform information
5. If your configuration includes DHCP and/or DNS, which interfaces will
it be enabled on?
6. If you have any static routes, NTP server and/or Zone Lab Server
specified with a hostname instead of an IP in your configuration, please
provide the IP address as well.
7. IP addresses of all interfaces on the ASA.
-heather
Overall Rating: 5 (4 ratings)
JORGE RODRIGUEZ Fri, 11/13/2009 - 10:28
  • Green, 3000 points or more
50+ L2L - Painfull!!
Have not come across a semeless way - and you know there is no utility that I know of Cisco has come up with - only a doc pdf file out there for just comparing sysntax .
In your situation I would probably have both in parallel and migrate each tunnel one at a time.
my 2 cents.
Todd Pula Fri, 11/13/2009 - 11:37
  • Silver, 250 points or more
TAC has a beta tool that can convert a 3k config to ASA format. It isn't a perfect conversion but probably better than starting from scratch. I would start by opening a case with TAC.
Correct Answer
hdashnau Fri, 11/13/2009 - 13:55
  • Cisco Employee,
it be enabled on?
-heather
JORGE RODRIGUEZ Sat, 11/14/2009 - 18:05
Is the conversion tool process only available via tac case?
mopaul Sat, 11/14/2009 - 21:31
  • Bronze, 100 points or more
Yes, because it's an internal tool. sorry.
M
JORGE RODRIGUEZ Sun, 11/15/2009 - 12:40
Thank you - but good to learn at least there is a tool / +5.
