Copy voicemessages from CUE
Nov 11th, 2009
Are the voice messages on CUE stored in .wave files, I am in a situation where I need to copy the user voicemessages ( if it's some .wave files) and send them as an attachement to their emails. I don't have acces to CUE and will appreciate if someone can help me verify it.
Appreciate your help on this...
Overall Rating: 5 (1 ratings)
anil.batra Wed, 11/11/2009 - 23:05
Thank you, Viverma. I can't back the data and restore since I want to copy the files ( is it's .wav) and send it via email to the user. This is because we are switching from CUE to Unity VM system.
virverma Wed, 11/11/2009 - 23:21
there's no way to pull these voice-mail recordings off CUE,
You can set up CUE 2.3 for message notification, where it will send a .wav
file to the users e-mail account when a message is left. You integrate this
with your e-mail server... So, if you were to configure this...the user
would have a record of the voice mail messages on hand to save. But right
now...if this isn't configured, there's no way of pulling them off CUE.
Here are your two options:
If you have an AIM-CUE, you can use Message Notification:
If you have an NM-CUE, you can use Integrated messaging using IMAP, or
messge notification (same as above).
