SSH access to c7200
Sorry for my bad English
I have following issue:
I have configured ssh server on c7200 appling following commands:
hostname R0
ip domain name cisco.com
username valera password 0 cisco
crypto key generate rsa
line vty 0 4
login
transport input ssh
and I try to establish ssh session with putty terminal. But I can to accsess to router. terminal ask me to enter login and password and give output access denied.
The output debug ip ssh:
Mar 1 00:07:50.010: SSH0: starting SSH control process
*Mar 1 00:07:50.014: SSH0: sent protocol version id SSH-1.5-Cisco-1.25
*Mar 1 00:07:50.094: SSH0: protocol version id is - SSH-1.5-PuTTY_Release_0.60
*Mar 1 00:07:50.114: SSH0: SSH_SMSG_PUBLIC_KEY msg
*Mar 1 00:07:50.202: SSH0: SSH_CMSG_SESSION_KEY msg - length 144, type 0x03
*Mar 1 00:07:50.202: SSH: RSA decrypt started
*Mar 1 00:07:50.383: SSH: RSA decrypt finished
*Mar 1 00:07:50.383: SSH: RSA decrypt started
*Mar 1 00:07:50.539: SSH: RSA decrypt finished
*Mar 1 00:07:50.547: SSH0: sending encryption confirmation
*Mar 1 00:07:50.551: SSH0: keys exchanged and encryption on
R0#
*Mar 1 00:07:54.505: SSH0: Installing crc compensation attack detector.
*Mar 1 00:07:54.509: SSH0: SSH_CMSG_USER message received
*Mar 1 00:07:54.509: SSH0: authentication request for userid valera
*Mar 1 00:07:54.513: SSH0: invalid old access type configured - 0x01
*Mar 1 00:07:54.513: SSH0: SSH_SMSG_FAILURE message sent
Can you help me?
adamclarkuk_2 Thu, 11/12/2009 - 01:24
  • Silver, 250 points or more
Are you using aaa for your authentication and wanting to authenticate locally, if so, change the login statement on your vty to be
login authentication
an example would using the default group would be:-
aaa new-model
aaa authentication login default local
line vty 0 4
transport input ssh
login authentication default
