Bring physical interface down (with object tracking)
Nov 12th, 2009
I have 2 connections to the ISP with iBGP peering between my router and the ISP's router.
Now one of the connections is a directly connected route, while the other connection (backup) is tunnel interface goes through 2 hops to the same router with higher AD.
When the main link (the directly connected one) goes down the bgp will take up to 3 minutes in order to fail-over to the tunnel interface even if I enable BGP fall-over.
If I bring down the physical interface (main link) then the bgp would fail-over in 3 seconds.
How would I bring down the physical interface based on object tracking?
Thanks in advance for your help
Mohamed Sobair Thu, 11/12/2009 - 01:47
  • Gold, 750 points or more
Hi Mohammed,
with Object tracking , you cant bring the physical interface down.
you have one of two options:
1- change the timers to a lower value.
2- use BGP next-hop tracking feature.
Mohamed
Mohammed Khair ... Thu, 11/12/2009 - 02:33
Hi Mohamed,
When changing the timers to lower value it will take too long to realize that the neighbor cant be reached through the physical interface, since the interface is in up/up or up/down state.
This case is the same as the one described above.
I do remember a solution where you can bring a physical interface down with unnumbered IP on it, but it was for serial interface (in my case its ethernet). I remember Brian Dennis from internetwork experts describing a way to do it, but I lost that CBT now.
