Stickness configuration
Nov 12th, 2009
Hi all,
I configured ACE like below configuration .so users connecting to server as http://10.244.0.50:7778 its oracle forms server.While users connecting through SLb they are getting disconnection in 1 min.How to create http cookie for this url.I tried to find out cookie in browse its not showing any cookie.
resource-class HTTP
limit-resource all minimum 10.00 maximum unlimited
boot system image:c4710ace-mz.A3_2_0.bin
hostname OICL_1
interface gigabitEthernet 1/1
switchport access vlan 100
no shutdown
interface gigabitEthernet 1/2
switchport access vlan 60
no shutdown
interface gigabitEthernet 1/3
shutdown
interface gigabitEthernet 1/4
shutdown
context Admin
member HTTP
[7m--More--[m
access-list ALL line 8 extended permit ip any any
access-list Realservertoslb line 1 extended permit ip any any
probe icmp ICMP
interval 15
passdetect interval 60
rserver host realserver1
description application
ip address 10.244.0.31
conn-limit max 4000000 min 2000000
probe ICMP
weight 20
inservice
rserver host realserver2
ip address 10.244.0.71
probe ICMP
weight 20
inservice
[7m--More--[m
rserver host realserver3
ip address 10.244.0.74
probe ICMP
weight 25
inservice
rserver host realserver4
ip address 10.244.0.77
probe ICMP
weight 30
serverfarm host HTTP_farm
retcode 200 500 check count
rserver realserver1 7778
conn-limit max 4000000 min 4000000
inservice
rserver realserver2 7778
inservice
rserver realserver3 7778
[7m--More--[m
inservice
rserver realserver4 7778
sticky ip-netmask 255.0.0.0 address both group1
serverfarm HTTP_farm
1 static client source 10.244.0.153 destination 0.0.0.0 rserver realserver1 77
78
class-map match-all HTTP_SERVICE
2 match virtual-address 10.244.0.50 tcp eq 7778
class-map match-all NAT_CLASs
2 match access-list Realservertoslb
class-map type http loadbalance match-any default-compression-exclusion-mime-typ
e
description DM generated classmap for default LB compression exclusion mime ty
pes.
2 match http url .*gif
3 match http url .*css
4 match http url .*js
5 match http url .*class
[7m--More--[m
6 match http url .*jar
7 match http url .*cab
8 match http url .*txt
9 match http url .*ps
10 match http url .*vbs
11 match http url .*xsl
12 match http url .*xml
13 match http url .*pdf
14 match http url .*swf
15 match http url .*jpg
16 match http url .*jpeg
17 match http url .*jpe
18 match http url .*png
class-map type management match-any remote_access
201 match protocol xml-https any
202 match protocol icmp any
203 match protocol telnet any
204 match protocol ssh any
205 match protocol http any
206 match protocol https any
207 match protocol snmp any
[7m--More--[m
policy-map type management first-match remote_mgmt_allow_policy
class remote_access
permit
policy-map type loadbalance first-match HTTP_SERVICE-l7slb
class default-compression-exclusion-mime-type
class class-default
compress default-method gzip
policy-map type inspect http all-match HTTP_SERVICE-http
class class-default
permit
policy-map multi-match NATpolicy
class NAT_CLASs
nat dynamic 101 vlan 100
policy-map multi-match int100
class HTTP_SERVICE
loadbalance vip inservice
loadbalance policy HTTP_SERVICE-l7slb
[7m--More--[m
loadbalance vip icmp-reply active
inspect http policy HTTP_SERVICE-http url-logging
Gilles Dufour Fri, 11/13/2009 - 00:35
  • Cisco Employee,
ace can create its own cookie
sticky cookie MyCookie ...
cookie insert
serverfarm ....
Then use the sticky-serverfarm above instead of your existing serverfarm.
Gilles.
