Difference between MSFC and RSM
Nov 12th, 2009
Hi All,
Can anyone provide me the difference between MSFC and RSM.
Giuseppe Larosa Thu, 11/12/2009 - 03:19
Hello Bala,
MSFC is a daughter card that provides routing services when installed on a C6500 supervisor.
Last generations of supervisors Sup720 are usually shipped with an MSFC3.
in old times MSFC could be added in a second time to make the device a multilayer switch.
First generation routing engine for C6000 was MSM that is a standalone linecard using a slot on the chassis.
the same should be true of RSM that should be a routing engine for C5500 series using a slot.
the C5500 equivalent of an MSFC should be named RSFC and should be a daughter card installed on supervisor.
Hope to help
vasanthbalajei Thu, 11/12/2009 - 21:34
Hi Giuseppe,
Thanks for your reply, so
MSFC - Layer 3 Switching
RSM - Routing Module for C5K series switches.
is my assumption correct.
Giuseppe Larosa Fri, 11/13/2009 - 04:41
Hello Bala,
also RSM can provide multilayer switching but in a C5500.
the MSFC is used on a C6500.
Hope to help
glen.grant Thu, 11/12/2009 - 05:07
Thats about it for differences , msfc high speed layer 3 board attached to the supervisor while a RSM on a 5500 was a standalone card usually in slot 2 . Layer 3 fast switching was handled and configured differently on the 5500's also .
