NM16ESW with HWIC-4ESW IN 2811 CHASSIS
Answered Question
I would like to know if some configuration exists so that these two cards work simultaneously. Since only HWIC works me. And when I remove HWIC it works me the NM-16ESW.
I ignore if you can configure a stack among both cards, or other solution.
Thank you
Correct Answer by Amit Singh about 7 years 7 months ago
Intra-chassis stacking is not possible with these two modules. You can run an ether-port from each module and cofigure it as a dot1q trunk in order to have ports in the same domain and configure them accordingly.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/prod_qas0900aecd8016c026_ps5854_Products_Q_and_A_Item.html
HTH,
-amit singh
Overall Rating: 5 (1 ratings)
glen.grant Thu, 11/12/2009 - 05:09
  • Purple, 4500 points or more
If you want both I believe you have to stack the cards together in order for both to work otherwise you can only have 1 installed . Do a search on the main page for stacking those hwics togther.
Correct Answer
Amit Singh Thu, 11/12/2009 - 05:33
  • Cisco Employee,
HTH,
-amit singh
