Cisco VPN Client and PIX-515E Unable to add route
Nov 12th, 2009
I'm encountering a problem with my Cisco VPN Client. I try version 4.8 and 5 with the same issues. I can successfully establish the ipsec tunnel but the routing table of my computer is not good.
Here is the log of the cisco vpn client :
Cisco Systems VPN Client Version 4.8.02.0010
Copyright (C) 1998-2006 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1 11:42:58.299 11/12/09 Sev=Warning/2 IKE/0xA3000067
Received Unexpected InitialContact Notify (PLMgrNotify:886)
2 11:43:13.659 11/12/09 Sev=Warning/2 CVPND/0xE3400013
AddRoute failed to add a route: code 87
Destination 172.16.255.255
Netmask 255.255.255.255
Gateway 10.0.0.1
Interface 192.168.65.41
3 11:43:13.659 11/12/09 Sev=Warning/2 CM/0xA3100024
Unable to add route. Network: ac10ffff, Netmask: ffffffff, Interface: aaa4129, Gateway: a000001.
4 11:46:02.512 11/12/09 Sev=Warning/2 IKE/0xA3000067
5 11:46:42.843 11/12/09 Sev=Warning/2 CVPND/0xE3400013
Gateway 10.0.0.1
6 11:46:42.843 11/12/09 Sev=Warning/2 CM/0xA3100024
and here is my PIX Version 6.3(3) configuration :
ip local pool vpnclient 192.168.65.1-192.168.65.254
crypto ipsec transform-set test esp-des esp-md5-hmac
crypto dynamic-map DMAP 10 set transform-set test
crypto map vpnclient 10 ipsec-isakmp dynamic DMAP
crypto map vpnclient client configuration address initiate
crypto map vpnclient client configuration address respond
crypto map vpnclient client authentication RADIUS
crypto map vpnclient interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp keepalive 10 3
isakmp client configuration address-pool local vpnclient outside
isakmp nat-traversal 20
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
isakmp policy 2 authentication rsa-sig
isakmp policy 2 encryption des
isakmp policy 2 hash md5
isakmp policy 2 group 1
isakmp policy 2 lifetime 86400
vpngroup info idle-time 1800
vpngroup vpnclient address-pool vpnclient
vpngroup vpnclient dns-server dns_server
vpngroup vpnclient wins-server dns_server
vpngroup vpnclient default-domain MENA
vpngroup vpnclient split-tunnel 102
vpngroup vpnclient idle-time 1800
vpngroup vpnclient password ********
Thank you for your help !
