Farrukh Haroon Sun, 11/22/2009 - 23:50
  • Red, 2250 points or more
Which version are you running?
What is the actual load on the sensor?
The load option is only supported on newer code using the following command:
"show statistics virtual-sensor | inc Load"
Farrukh
[email protected]
Im facing high cpu usage in my 4200 device. The output of "top" is attached.
i have not enabled iplog in ips.
Pls provice an immediate solution if possible.....
~pr
