Errdiable Trap on LMS3.2
Answered Question
Nov 12th, 2009
Hi;
We enabled Bpduguard on our access layer switches and enabled SNMP Traps for errdisable. Eventhough i can see them sending traps i can't see them on ciscoworks. So can someone help me on creating a Notification Trap on Cisco LMS3.2
I can see all other traps apart from Errdisable traps.
Thanks in advance
Rams
Correct Answer by MICHEL.HEGERAAT about 7 years 2 months ago
Yes you can.
Using the "automated actions" in RME you can use these syslogs messages to trigger the sending of a mail or even running a script.
Cheers,
Michel
Correct Answer by Joe Clarke about 7 years 2 months ago
LMS is not a general trap receiver. It will not process errdisable traps. If there are syslog messages associated with ports going to an errdisable state, you will be able to view those in RME. Just make sure the devices are sending syslog messages to the RME server, then you can view the messages by going to RME > Reports > Report Generator, and running a syslog standard report.
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Thu, 11/12/2009 - 09:58
Rams.Dandu Fri, 11/13/2009 - 00:46
Hi Clarke;
Thanks alot for the help. Instead of running reports everyday and checking the syslog messages.Is there any other way to pro-actively report the err-disabled ports.
Thanks in advance.
Regards;
Rams
Correct Answer
MICHEL.HEGERAAT Fri, 11/13/2009 - 02:33
Yes you can.
Cheers,
Michel
