DMVPN & EzVPN
Nov 12th, 2009
Hello everyone , I have configured DMVPN Hub and EzVPN Server on Cisco 2811 at the headoffice and the branches are having 2600 routers . There are 5 Spokes at this moment for DMVPN . Users use Cisco EzVPN Client software to access HeadOffice network . However I am facing problems .
when i do sh crypto isakmp sa
I usually see errors like
MM_NO_STATE
CONF_XAUTH
And the IP address in the destination is the spokes of DMVPN . sometimes when i type in the HUB
crypto isakmp key cisco123 address 172.19.7.122 no-xauth
static entry for DMVPN spoke and type no-xauth , it works fine sometimes but sometimes not . I could not test all the spokes at this moment because the network is not in production at this point .
I think the ezvpn server and dmvpn server is having a conflict in this crypto isakmp key thing .
Attached is my DMVPN HUB + EZVPN Server configuration
Todd Pula Thu, 11/12/2009 - 14:51
  • Silver, 250 points or more
You will want to modify your configuration to use an isakmp profile. This will allow you to apply the EasyVPN xauth config to your incoming client connections only. For example,
crypto isakmp policy 2
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto isakmp client configuration group testgroup
key testgroup
pool vpn-test-pool
crypto isakmp profile vpn-test-profile
match identity group testgroup
client authentication list VPN
isakmp authorization list VPN
client configuration address respond
crypto ipsec transform-set test esp-3des esp-md5-hmac
crypto ipsec profile test-profile
set transform-set test
crypto dynamic-map dyn-map 1
set isakmp-profile vpn-test-profile
reverse-route remote-peer 1.1.1.1
crypto map test 1 ipsec-isakmp dynamic dyn-map
