Static NAT Config - Not able to telnet/Ping/FTP the VIP
Nov 12th, 2009
I have a VIP for which I have configured static NAT with a private IP. Now I am seeing that I am unable to telnet or FTP or ping to that VIP from that private IP. I can ping other VIPS from the same private IP and I can ping the VIP from other private ip addresses. Below is my configuration.
access-list somecompany_statnat_206.32.55.115 line 8 extended deny ip host 172.16.234.30 172.16.0.0 255.252.0.0
access-list somecompany_statnat_206.32.55.115 line 10 extended deny ip host 172.16.234.30 172.16.84.0 255.255.
255.0
access-list somecompany_statnat_206.32.55.115 line 16 extended permit ip host 172.16.234.30 any
class-map match-any somecompany_statnat_206.32.55.115
2 match access-list somecompany_statnat_206.32.55.115
class somecompany_statnat_206.32.55.115
nat static 206.32.55.115 netmask 255.255.255.255 vlan 600
policy-map multi-match SOMECOMPANY_SNAT_POLICY
interface vlan 1234
description somecompany_dmz
ip address 172.16.234.2 255.255.255.0
alias 172.16.234.1 255.255.255.0
peer ip address 172.16.234.3 255.255.255.0
access-group input somecompany_dmz_acl
access-group output all
nat-pool 1234 206.32.55.110 206.32.55.110 netmask 255.255.255.255 pat
service-policy input remote-mgmt
service-policy input INSPECTION_POLICY
service-policy input SOMECOMPANY_SNAT_POLICY
service-policy input SOMECOMPANY_NAT_POLICY
service-policy input Virtual_IP
no shutdown
Below is also the Server to VIP configuration. This is for allowing the Private IP to access the VIP. access-lists for the ports have not been mentioned but have been allowed.
access-list SOMECOMPANY_SERVER_TO_VIP extended permit ip 172.16.234.0 255.255.255.0 host 206.32.55.115
class-map match-any SOMECOMPANY_SERVER_TO_VIP
2 match access-list SOMECOMPANY_SERVER_TO_VIP
policy-map multi-match SOMECOMPANY_NAT_POLICY
class SOMECOMPANY_SERVER_TO_VIP insert-before somecompany_nat
nat dynamic 1234 vlan 1234
Appreciate your help
