two MST regions
Nov 12th, 2009
1) If two different MST regions with instances MST0 MST1 and MST2 are interconnected, root bridge for MST1 and MST2 should be inside corresponding region. Shall root for MST 0 instance be only in one region on bridge with lowest priority?
I know that when PVST+ is connected to MST, if MST switch receives BPDU that claims that root is in PVST+,ROOTGUARD automaticly blocks this port.
What happens beetwen two MST regeions?
2) Further more if one region has IEEE MST and other has pre-standard MST should there be a problem if IEEE MST switch toward pre-stanbdard switch doesn't have configured interface as "spanning-tree mst pre-standard" ?
Because I have situation where "show spanning-tree mst interface detail" on IEEE MST swith shows :
Boundary : internal pre-standard (rcvd)
and on the other side of the link on pre-stanndard MST shows :
Boundary : boundary
It seems that IEEE MST regionn considers pre-standard MST region as internal, but pre-standard MST considers interface toward IEEE MST as boundary (as it should be)
thanks in advance,
