TFTP: [17]:Error --> File not found
Nov 12th, 2009
hello, i'm trying to add some background pictures to my phone, done what needed,
List.xml, two png images, but image does not appear
i've seen console logs and there is a message
TFTP: [17]:Requesting Desktops/320x196x4/List.xml from *.*.*.*
can anyone help?
Jaime Valencia Thu, 12/03/2009 - 19:46
  • Cisco Employee,
  • Hall of Fame,
    2011
That size is for 7962G, 7942G, 7961G, 7961G-GE, 7941G, and 7941G-GE. I'll assume you're using one of those, if not, go to CCO and search " + administration guide" to get the right set of instructions
Creating Custom Background Images
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7962g_7961g_7961g-ge_7942g_7941g_7941g-ge/7_1/english/administration/guide/62614241cus.html#wp1030672
Most common errors are:
A) Use instructions for another model, thus creating the PNGs and folders incorrectly
B) Copying the contents of List.xml directly from the webpage, there are hidden characters when you copy paste and cause errors
C) Linux is case sensitive, and the files and/or contents are not correct. List.xml is not the same as list.xml for Linux, neither .PNG and .png
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
