Problem with HUM and Cisco 6500
I've problems with hum and cisco 6500, the interface utilization is not working except for 2 interfaces which run older systems with 10 half duplex. Everything higher is not working.
Errors:
ifHCOutOctets Gi1/1 Permanent 1 No Such Instance - The specified instance is not available Thu, Nov 12 2009, 17:42:11 CET
ifHCInOctets Gi1/1 Permanent 1 No Such Instance - The specified instance is not available Thu, Nov 12 2009, 17:42:11 CET
ifHCInOctets Gi1/10 Permanent 1 No Such Instance - The specified instance is not available Thu, Nov 12 2009, 17:42:11 CET
ifHCOutOctets Gi1/10 Permanent 1 No Such Instance - The specified instance is not available Thu, Nov 12 2009, 17:42:11 CET
ifHCInOctets Gi1/11 Permanent 1 No Such Instance - The specified instance is not available Thu, Nov 12 2009, 17:42:11 CET
ifHCOutOctets Gi1/11 Permanent 1 No Such Instance - The specified instance is not available Thu, Nov 12 2009, 17:42:11 CET
ifHCInOctets Gi1/12 Permanent 1 No Such Instance - The specified instance is not available Thu, Nov 12 2009, 17:42:11 CET
ifHCOutOctets Gi1/12 Permanent 1 No Such Instance - The specified instance is not available Thu, Nov 12 2009, 17:42:11 CET
Templates used:
Template Details
Template Name: Interface Utilization MIB2
MIB Variables: ifSpeed
ifInOctets
ifOutOctets
ifInOctets
ifOutOctets
I was able to load this template and add it to the device that was giving me errors and remove the Interface Utilization and now I do not get the errors.
11 Replies 11
Joe Clarke
What version of HUM are you using? What version of code is running on this switch? Post the running config of the switch.
LMS 3.2 with HUM 1.2.0
Cisco 6509
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(33)SXH3, RELEASE SOFTWARE (fc1)
Thanks.
I see no reason why the high capacity counters would not be populated for these interfaces. Post an SNMP Walk of the ifTable and ifXTable using SNMPv2c for this device.
I used an extra self made template, and now it works....
I also changed the retry counter.
Thanks for your support.....
I got the same problem. Could you explain how you created a extra self made template?
Ken
I think that the retry counter fixed the problem.
Try that first....
Henk
Thanks for the reply. I changed the retry counter from 1 to 3 but got the same error. I got a template for monitoring interface utilization from slower speed interfaces by calling TAC per another forum discussion with same problem. Its been 4 hours and I have not recorded 1 error.
Thanks for your reply.
Can you post that template overhere?
Henk
Thanks, I will try this one too.
Henk
Would this template works for a 3750?
Thanks.
