How to prefer Voip DP over Ephone-dn extension
Nov 12th, 2009
If i have a voip dial peer with destination pattern 4... and session target to a CUCM and have ephone-dn 10 with extension number 4000 configured on the same gateway.
If an incoming call comes into the DID for extension 4000 it sends the call to ephone-dn 10. I would like to setup the gateway so that incoming call for extension 4000 tries the voip DP first with pattern 4... and route the call to the CUCM First. If that call routing is not available then send call to ephone-dn 10
I have tried preference with no luck.
Any ideas
Chad Stachowicz Thu, 11/12/2009 - 11:52
Seems very silly, however I would create 2 DP's... and change the ephone-DN to another number... The first Dial peer keep as normal, the second DP, make a translation pattern and home it to your router with translating 4000 to your new ephone dn..
