Building a 3120 Stack
Nov 12th, 2009
I have four 3120's in an HP blade system that are currently configured as 4 standalones. I want to stack them. is it as easy as configuring the first one as switch 1 and then connecting the stackwise cables? Will I need to reboot anything?
Overall Rating: 4 (1 ratings)
francisco_1 Thu, 11/12/2009 - 11:40
  • Gold, 750 points or more
Nope!.
Before you connect the switch modules in a stack, keep in mind these stacking guidelines. You should install the stack master switch module and run the initial setup program on that switch module before you connect the StackWise Plus cables to other stack members
see http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01430321/c01430321.pdf.
