FoIP and VoIP on the same router
Nov 12th, 2009
Would anybody know of a best practice document that I can refer to for both FoIP and VoIP to be configured on the same Voice Gateway? here is an example. We have 6509 cores with a ccm module that will have 3 PRI (Two for voice and one for fax) how would we go about for the config for our voice gateway to let voice be priority out as we don't want the outgoing faxes to get in the way.
julienf28 Tue, 01/19/2010 - 08:34
I have the answer,
Instead of having destination-pattern .T (which grabs everything) you can have a range of numbers i.e. Destination-pattern 3000-3999. this will grab all numbers in that range and send it to the FoIP.
J
