Show int "Last input never" but counts are g.t. zero?
Answered Question
Nov 12th, 2009
I am trying to decide how recently an interface has been used, if at all. "Show int" says, "Last input never, output 1w 3d", but the input counts are all greater than zero. The link of course is down. How does this happen? Or am I misinterpreting what "Last input never, output never" means?
> show int fa0/5
FastEthernet0/5 is down, line protocol is down
Hardware is Fast Ethernet, address is 0004.27cd.4345 (bia 0004.27cd.4345)
MTU 1500 bytes, BW 0 Kbit, DLY 0 usec,
Keepalive not set
Auto-duplex , Auto Speed , 100BaseTX/FX
Last input never, output 1w3d, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
693231 packets input, 65801676 bytes
Received 5831 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 5056 multicast
928808 packets output, 552742079 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
Correct Answer by arjmenon about 7 years 3 months ago
http://www.cisco.com/en/US/docs/ios/interface/command/reference/ir_s4.html#wp1014358
Last input
Number of hours, minutes, and seconds since the last packet was
successfully received by the interface and processed locally on the
router. This field is useful for detecting when a dead interface failed.
Note This field is not updated by fast-switched traffic.
on the c4500 we have the "sh interfaces link in CLI"...
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Thu, 11/12/2009 - 23:57
Hello Wiley,
on some switches I could see last input never for live ports with traffic over it!
this should be what Cisco would call a cosmetic bug.
Hope to help
Giuseppe
iyde Fri, 11/13/2009 - 09:18
Hi.
Quite right! In some Catalyst switches (I believe Cat3550 and older) this bug is present. You can have an interface which is up/up and a lot of traffic running across but it still says "Last input never".
This cosmetic bug never got fixed - I expect that it is a hardware limitation.
HTH, Ingolf
Correct Answer
arjmenon Fri, 11/13/2009 - 23:57
Last input
