TwinAx 10GB Nics
Nov 12th, 2009
I am trying to push a Nexus solution in the Datacentre, but I am having trouble getting a list of 10GB NICS (not CNA) that I can use the Cisco Twinax cable with.
Does anybody have a list?
a12288 Fri, 11/13/2009 - 12:21
twinax cable has 2 pre-modeled CNAs at both side.
mmacdonald70 Sun, 11/15/2009 - 05:15
The TwinAx has optics attached but still need to plug into a NIC (SFP+) this is what i was looking for
a12288 Sun, 11/15/2009 - 19:43
Every 10G switch or server supports sfp+ would do, as Twinax is just A type of media, while it can only a very short distance.
Peter Thomas Thu, 01/17/2013 - 03:47
Cisco has their own SFP/SFP+ modules & cables, however you may need to check the chipset on the TwinAx cables as some passive twinAx are not compatible with certain HP network adapters or SAN solution i.e. EMC.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/installation/note/78_15160.html
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
