NetFlow on Catalyst 4500-E Series
Answered Question
Nov 12th, 2009
Anyone know if a Supervisor 6-E will support NetFlow on a Catalyst 4507R-E?
If not, what are my options for NetFlow on a 4507R-E?
Correct Answer by Marvin Rhoads about 7 years 8 months ago
From : http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/configuration/nfswitch.html
...Supervisor Engine 6-E and Catalyst 4900M chassis does not support Netflow.
...To use the NetFlow feature, you must have the Supervisor Engine V-10GE (the functionality is embedded in the supervisor engine), or the NetFlow Services Card (WS-F4531) and either a Supervisor Engine IV or a Supervisor Engine V.
Overall Rating: 5 (1 ratings)
Correct Answer
Marvin Rhoads Thu, 11/12/2009 - 19:37
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
SimGuy7474 Thu, 11/12/2009 - 20:17
That's what I was afraid of.
I'm guessing my only options to have both 10 Gbps link capabilities AND NetFlow are to move to the Catalyst 6500 series then.
francisco_1 Fri, 11/13/2009 - 03:03
  • Gold, 750 points or more
you dont have to move to 10GB sup engine to support netflow. As suggest you can buy daughter card netflow expasion module WS-F4531 for your Supervisor Engine 6-E instead. this option is cheaper.
SimGuy7474 Fri, 11/13/2009 - 07:00
I was under the impression that the WS-F4531 only was able to be used with either the Sup-IV or else the Sup-V engines?
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
My ultimate goal would be to support 10 Gbps flows with a 4500-E series chassis while also having NetFlow. However, it's seeming that it's not possible and that they are mutually exclusive on the 4500-E series chassis.
francisco_1 Fri, 11/13/2009 - 07:49
sorry yes you are right! While i was writing my suggestion it skipped my mind you are not using Sup-IV/ Sup-V engines
industriashaceb Thu, 03/08/2012 - 08:49
Good Morning.
I have a switche Cisco Catayst 4507R+E and two Sup 7-E 10GE (SFP+), 1000BaseX (SFP), and i couldn´t configured the Net Flow, i was reading cisco forums, but in couldn´t find information important... somebody can help me?
I can´t activate the enable command #ip flow-cache, for activate in the interfaces.
thanks.
Don Jacob Sat, 03/17/2012 - 00:26
  • Bronze, 100 points or more
Cisc SUP 7-E supports Flexible NetFlow export. Can you try configuring as below and check. Remember to use IP Address as per your network.
flow exporter NFAexporter
    destination 192.168.1.1
    output-features
    transport udp 9996
flow record NFArecord
    match ipv4 source address
    match ipv4 destination address
    match transport source-port
    match transport destination-port
    match interface input
    match ipv4 protocol
    match ipv4 tos
    match ipv4 dscp
    collect routing source as
    collect routing destination as
    collect routing next-hop address ipv4
    collect transport tcp flags
    collect counter bytes
    collect counter packets
    collect timestamp sys-uptime first
    collect timestamp sys-uptime last
    collect interface output
    collect flow direction
    collect ipv4 id
    collect ipv4 source mask
    collect ipv4 destination mask
flow monitor NFAmonitor
    record NFArecord
    cache timeout active 1
    cache timeout inactive 15
Associate the monitor to the interfaces - Apply on all interfaces of the switch
interface GigabitEthernet 0/1
     ip flow monitor NFAmonitor layer2-switched input   - Will capture both switched and bridged traffic
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
