SCCP MTP registration issue with CUCM 6.14
Nov 12th, 2009
  • Green, 3000 points or more
I have the following:
(3) DSP 64 chips
(1) PRI
(1) FXS 4/did card
There is something goofy with this new "Version" on SCCP commands.
If I use version 3.1 on my SCCP, My CFB and xcode works fine, but my MTP will not register.
If switch to Version 6.0 for SCCP, my MTP, but then CFB and xcode will not register.
12.4(22)T2 is on the router.
Its a basic config.
sccp local Loopback0
sccp ccm XXX.XXX.XXX.XXX identifier 2 version 3.1
sccp ccm XXX.XXX.XXX.XXX identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register FRE11_XCDR
associate profile 2 register FRE11_CFB
associate profile 3 register FRE11_MTP
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 8
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
dspfarm profile 3 mtp
description Media Termination Point
codec g711ulaw
maximum sessions hardware 8
I hunted the bugs, cant find anything.
Tommer Catlin Fri, 11/13/2009 - 18:59
Ok, can anyone tell me why this configuration works? notice the versions are different for MTP and xcode and transcode CCM? But this is the only way I could get it to work??
sccp ccm 172.19.20.10 identifier 2 version 6.0
sccp ccm 172.19.20.11 identifier 1 version 3.1
sccp
sccp ccm group 2
associate ccm 2 priority 2
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 9
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
codec g711ulaw
maximum sessions software 100
Tommer Catlin Fri, 11/13/2009 - 19:48
I love a thread I an answer myself, that I started.
So...... After CUCM 5.x, it only uses Enhanced for Transcoders and Conference bridges.
MTP by default uses Enhanced, no other option.
So when I configured SCCP Version 3.1 with standard bridge and xcoder, it worked fine.
But in SCCP 3.1, MTP was not introduced yet in CUCM.
This is why MTP worked with 7.0 or 6.0 or whatever.
So, changed the bridges and xcoders to enhanced, then changed my versions in SCCP to 6.0 and everything worked.
It throws you off because 3.1 actually works fine with standard in CUCM. but if you require MTP, everything has to be enhanced.
Enjoy
