QUESTION onf Extended ping
Nov 12th, 2009
Hi all
may be a its simple question, but i gues it will help a lot for others
when i do ping to device in network it is not reachable but if i do wxtended ping with one of the ip its pingable
can some one tell me how does this work
the device from which i tring ti ping is a Core switch mutileple vlan itnefaces
Adhitya
Overall Rating: 4 (1 ratings)
Joe Clarke Thu, 11/12/2009 - 20:30
What additional options do you specify when doing extended ping? It could be that the destination does not have a route back to the default source IP, but does to the IP address used in the extended ping.
adhityakarthik Thu, 11/12/2009 - 20:39
Thanks for the response
I used extended ping and sources address is the one of the ip address of the switch(vlan interface IP) and destination ip
is ip of the detination server
regd
Adhitya
Joe Clarke Thu, 11/12/2009 - 21:00
Then the default source address for the ping must either not be allowed to get to the destination, or the destination does not have a route back to that address. You could use a sniffer to confirm where the traffic is being dropped.
