IP Telephony and Phones
Labels
Dear Sir i am new to 8851 ip phone , just need help for speed dial kem i do program speed dial entries into the device and when the phone is turned off the entries are lost is there is any advice why list is forgotten from the phone ? thanks
heamer by Level 1
  • 17 Views
  • 0 replies
Hi all. In the screenshot I encountered a problem: immediately after turning it on, this appears. Has anyone else encountered this problem? It asks for a domain, username and password. The phone is completely new. There is a way to access the setting...
My company has 4 Call Manager subscribers, two at our HQ datacenter and two at our colocation.   We powered down everything at our colo this part Saturday because we are moving it out of state.  Since then, we have had random locations having switch ...
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
I have headset Bluetooth paired with cisco phones and working fine, but auto answer not work. I tried to enable Auto answer with headset on DN but still any incoming call on phone not auto answer, is there anything I miss other than configure auto an...
matee by Level 1
  • 333 Views
  • 12 replies
Cisco C8000V. Cisco IOS XE Software, Version 17.06.05. Trying to implement static PAT to translate SIP traffic between private and public voice gateways.<172.17.20.36:3002>    <Cisco NAT 1.2.3.4>      <5.6.7.8:5060>ip nat inside source static udp 172...
mpla by Level 1
  • 104 Views
  • 3 replies
