11-13-2009 12:42 AM - edited 03-06-2019 08:35 AM
hello
does anybody know if the catalyst switch 4510R-E works with only one Supervisor Engine plugged?
thanls
Solved! Go to Solution.
11-13-2009 03:15 AM
Supervisor engine is required for the 4510-r switch to work as the ios is present in the supervisior engine ony.
11-13-2009 03:18 AM
Bill,
Yes it will work with only one Sup but Cisco Catalyst 4510R-E supports redundant supervisors to minimize downtime.
this link will help http://www.cisco.com/en/US/products/ps9297/index.html
11-13-2009 03:55 AM
Yes it does. Both the 4507 and 4510 allow for redundant supervisors but there is no need to have the redundant supervisor for the switch to run.
Jon
11-13-2009 03:15 AM
11-13-2009 03:18 AM
Bill,
11-13-2009 03:57 AM
Franco
Apologies for repeating what you have already said, i don't usually do that !!.
I missed your response and just read the first one which didn't specifically answer the question.
Jon
11-13-2009 04:09 AM
no worries Jon.
11-13-2009 03:55 AM
Jon
